BIOS Legion 5-15ARH05 (Lenovo) EUCN22WW AMD GY535/GY536 NM-D191 REV: 1.0
BIOS GY535/GY536 NM-D191 REV: 1.0
NM-D191REV1.0.pdf
DB.pdf
NM-D191REV0.2.tvw
LENOVO_IDEAPAD_GAMING3_LCFC_NM-D191 photo
EC.zip
DB.pdf
NM-D191REV0.2.tvw.zip
NM-D191REV1.0.pdf
Hola administrador, puede por favor pasar la configuracion para un SVOD4? el equipo se enciende automaticamente y se queda en 0.220 mAh de consumo y parpadean los leds, el ITE de la placa esta alimentacion con el LDO de 3v y las fuentes de 3v y de 5v estan presentes.
ite name ?
DESPUES DE UNA ACTUALIZACION SOLO HAY IMAGEN POR PANTALLA EXTERNA. NO HAY IMAGEN POR LA PRINCIPAL.... AYUDAME!
BACKUP.bin
Merhaba cihaz lenovo ideapad gaming 3-15arh05 (nm-d191 rev:1.0_gy535/gy536)
işlemci: amd ryzen7
GPU:N18P-G62-A1
KENDİ ESKİ BİOSU GÖRÜNTÜ VERMİYOR.BURDAN BAŞKA Bİ BİOS YAZDIM GÖRÜNTÜ ALDIM FAKAT GRAFİK KARTI ÜNLEM İŞARETİ VERİYOR.KENDİ BİOSUNU DÜZENLEYEBİLİŞRMİSİNİZ TESEKKURLER.
çöp.BIN
işlemci: amd ryzen7
GPU:N18P-G62-A1
AMD bios no have any edit
PEKİ BU EKRAN KARTINA UYUMLU BİOSU VEREBİLİRMİSİN.?YAZDIGIM BİOSTA ÜNLEM İŞARETİ ATIYOR(!)
I can't tell which bios is suitable for you if you don't submit it above there are many bios you can try and it's very possible that the GPU also has a problem.
