This unit operates by electricity. And some components within the
device have high dangerous voltages applied to them.
• Failing to follow the operating instructions could result in death,
serious injuries, and/or extensive damage to property!
• Never open the housing or one of the Infrared heaters while main plug
is connected.
• Do not use the units for any purpose other than which they are
intended to. Use it according to the operating instructions.
• This equipment must not be switched on or used without supervision.
• The unit should switched‐off or in idle state while not in use, leaving it
ON may cause overheating.
• Do not place any flammable material on the vicinity of the Infrared
heater.
• Do not allow the spillage of any liquid to on the ceramic emitter as
damage may occur.
• Please use the Infrared heater only on a level and non flammable
surface.
• When the Infrared heater is in use, its housing and the areas exposed to
the infrared rays can reach high level of temperature. Please do not
touch the housing until it cooled down.
• Any maintenance of the units is only permitted by a JOVY SYSTEMS
certified service technician.
• Please also pay attention to the safety regulations applied in your area.
RE-7500-Manual-English.pdf
