1.8.0.bin.zip
[email protected]
This bios tow problemsView attachment 186086Inspiron 7506 2-in-1 HELLCAT 19859-1
Try all BIOS same problem ?This bios tow problems
One not detect SSD
Tow not allowed any service tag please help
for this modal i try 2 bios please send me worked biosTry all BIOS same problem ?
This laptop worked ok but have pass before from other shop lose orginal bios hardware is oki also can't tell which BIOS is working problem SSD can't check from BIOS if there are two BIOS same problem then next you need to check hardware.
PLASE HELPView attachment 186086Inspiron 7506 2-in-1 HELLCAT 19859-1
need use two bios otherPLASE HELP
want set tag you need buy patch 35$can u set service tag 92XP762 IN BIOS NOT SAVE
CAN U DISCOUNT TO 20$ PLASE ?want set tag you need buy patch 35$
OK YOU CAN SET ANY SERVICE TAG ONLY IN BIOS SHOWED AND FIX MANUFACTURE PROGRAMING MODEIf you don't need the correct old TAG, I recommend you use another pair of BIOSes, the BIOSes that are backed up from the machine will have the TAG available.
I USED MORE THAN 6 BIOS ALL NOT ALLWOED SERVICE TAG AND SOME BIOS HAS TPM PROBLEMIf you don't need the correct old TAG, I recommend you use another pair of BIOSes, the BIOSes that are backed up from the machine will have the TAG available.
Alt+F not oK ?OK YOU CAN SET ANY SERVICE TAG ONLY IN BIOS SHOWED AND FIX MANUFACTURE PROGRAMING MODE
I RECORED VEDIO TO SEENAlt+F not oK ?
