BIOS Inspiron 3505 GDI53 LA-K001P
GDI53 LA-K001P AMD
Dell Inspiron 3505 Compal LA-K001P r1.0.pdf
DELL_INSPIRON_3505_COMPAL LA-K001P photo
Inspiron 3505​
There is a lot of bios you can use but I think you need to check AMD chipset
I'm referring to the EC file you uploaded, which won't turn on, and nothing else. I replaced the KBC with an identical one; it turns on, but the logo remains. I assume the KBC doesn't have the correct programming since it was taken from another computer. I need to know if you can provide me with a working EC file. Thank you very much, dear.
EC.bin.zip
If it has nothing to change compared to before programming, you need to check another part
EC.bin.zip
This KBC information I'm attaching is for a different motherboard, but with the same numbering. It powers on, but doesn't go past the LOGO. The EC you sent me doesn't power on. I need information on the GDI53 LA-K001P EC that powers on.
I think you need to check other components EC I provide is good
The EC information you have, which doesn't go beyond the LOGO, is from another LA-L245P unit. The EC information you provide doesn't even activate the ignition; it doesn't do anything; it doesn't turn on. That's why I'm asking if you could help me with an EC that will turn on the unit. If the EC provided is good, the equipment should turn on. Thank you very much.
