BIOS Ideapad 3 15iil05 - NM-D031
boardview Lenovo Ideapad 3 15iil05 - NM-D031 REV1.0 BoardView.tvw.zip
Lenovo IdeaPad 3 15IIL05 - GS454-GS554 NM-D031.pdf
ideapad 3-14IIL05, ideapad 3-15IIL05, ideapad 3-17IIL05, V17-IIL S350-1415IIL EMCN54WW
sorry, but with this file, i got no image, and the computer restarts( turn the LED off and on) every 20/30 seconds
Because the customer wants.... i don't give a damn why.
The laptop have a 32Gb DDR4 installed.
can you please try to get me another bios file ..
thanks
I've talked to the customer, and he says that sometimes the computer gives a blue screen error, and he have runned memtest (removing the ddr4 memory in the slot) and he throws some errors.
That's why he wants to disable onboard ram.
Can you please help ??
I'm sending the original file again
Thanks
Tried bios above working but battery is missing cannot use with battery. attached my original file issue no power.
Sir After flashing your bios can Power On now,But when inserted a battery cannot power.battery is Good i need to short the cmos backup battery to make Laptop pwr On but without battery, Can You Rebuild my bios it does not power.
not problem bios
you need check chipset
not problem bios
i incorrectly flash the bios this one Ideapad 3 15iil05 - NM-D031 and reflash with this ideapad 3-14IIL05,
though its working now but my problem is the power switch not working even 3.1v is present..It will power up with charger but the power button not function 3,1v is present can you build my bios
