Locked.. usercred is bigger than normal hp.HP ProBook 640 G5 6050A3028601-MB-A01(A1)
BIOS R72
try itLocked.. usercred is bigger than normal hp.
HP-640-G5
MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.www.mediafire.com
not work. 16mb also needs edit .. new security in thesetry it
16MB can not edit.not work. 16mb also needs edit .. new security in these
"endpoint security controller" error
ok flash original back and now MPM unlock .. seems 32 mb clean did change 16mb.. will check and tell more later.16MB can not edit.
at this time must accept this error because there is another solution
You say BIOS thisok flash original back and now MPM unlock .. seems 32 mb clean did change 16mb.. will check and tell more later.
yes ..You say BIOS this
unpas1111.zip ?
password why request clear me?
Not same is different both 16mb fileyes ..
seems 32 and 16 mb are both same. but 32 has descriptor and ME regions.so 16mb is copy of 32mb bios region.
flash original 32 mb back after cleanpwd is flashed.my lap
power on password butt i remove password in 32mb after remove password show one error
