32MB.BIN
16MB.BIN
HP_ELITEBOOK_X360_1030_G4_QUANTA Y0PA photo.zip
PLS PASSWORD BIOS
THE PASSWORD NOT ERASE
PLZ CLEAR PASS
DAY0PAMBAF0
Have password,can you unlock?
returm bios old and send i one photo display lockWith your dump turn on,no keyboard backlight,only light caps lock,no fan spin,no display
unlock via 32MB Please not Programming 16MBI use your 16MB above to remove the setup password
the password removed but an error message appears when powering on
"There is a problem with the security device on the unit"
Thank youunlock via 32MB Please not Programming 16MB
You can unlock via 16MB but you need modyfi oryginal file, you can't take file from other laptop!!Thank you
how I can modify the original?You can unlock via 16MB but you need modyfi oryginal file, you can't take file from other laptop!!
Then when you reset via bios security setting to default, then error notifi was REMOVE for ever - work only with oryginal 16MB file.
I often use UEFI Tool to create the new bios with bios region downloaded from the support website, but in this case the only firmware available at hp site has 29MB. in specific cases it is necessary to cut the appropriate part of firmware with HEX editor I have already used this method with dell bios. I think I have to try it.
if you have another method you can help me.
Thank you
Thank you in advanceSend me 16MB file i will unlock for U.
