How to Find Model Name Asus
Motherboard
Method 1 : Rebooting your system
Hit the "Pause/Break" key when you see ASUS XXXX ACPI BIOS Revision
For example:A7N8X-VM represents the motherboard model.
Method 2 :Please find the model name from the motherboard surface
If necessary, please open the system case for better inspection.
For example:P4C800-E represents the motherboard model
Notebook
Method 1 : You can find the model name on the label which is pasted on the back of the laptop.
For example: X302LA
Method 2:
For example: X550WE REV 2.0
PadFone & ZenFone & FonePad
• Please go to Setting->About->Model number to check the model name. (For Zenfone/Padfone/Fonepad)
• Please check the package box for sticker label. The model name is listed on sticker label For ex sample : ASUS_T00F (A500CG). (For Zenfone/Padfone/Fonepad)
• Please check the package box for sticker label. The model name is listed on sticker label as red mark. (For Zenfone/Padfone)
• A. Turn off the device and pull the rear cover off. The model name is listed on sticker label. (For Zenfone/Padfone)
• B. Check the back of the tablet and the model name is listed on the case. (For Fonepad)
• Please check the cover of user manual. (For Zenfone)
Zenwatch
Method 1 : Please check your Zenwatch back cover. Here you could find the model name.
Method 2 :Please check the package box for sticker label. Here you could find the model name.
Eee PC
Method 1 : Please close the opening lid and flip the EPC with its back facing upward. Your model name will be printed on the red section.
For example:701 (model name.)
Motherboard
Notebook
For example: X302LA
Method 2:
Zenwatch
Eee PC
