It remains to be determined whether the problem is from the BIOS or whether the SSD itself or the Motherboard has a hardware problem@ThienBui if i understand correctly there is no possible way to get the ssd drives to detect if the original bios can not be repaired?
gracias por el aporte, pero la 1A no es la misma, las lineas cambian desde conectores y mosfet entre otras cosas
là ko nhận SSD M2 chứ gì ?A FIX HO EM VOI,MAIN CHET CHIP NAM THAY OK NHUNG K BOOT DC SSD TKS
EM CHEP FILE CUA A OK AH TKS Alà ko nhận SSD M2 chứ gì ?
Admin,please unpass bios,Thanks!
LA-L191P plz build it . power on or off
ready builds according to your requirements if builds don't work you can try adding another biosno power on this bios
yes i check another bios but ssd not detect i atch ssd not detect biosready builds according to your requiremeyes nts if builds don't work you can try adding another bios
SSD M2 does not work with BIOS clearme.yes i check another bios but ssd not detect i atch ssd not detect bios
this one is orignal bios can you fix it power on or off isssuSSD M2 does not work with BIOS clearme.
clsss.binNEED CLEAN ME
