BIOS Flex 5-14ITL05 LC56-14T 203013-1
Hi ThienBui,
could you please help to fix the attached bios?
I5 (11th)
LC56-14T
203013-1
448.OK121.0011
Crashes / get stuck during boot. (SSD & USB)
Tried other bios from this thread.
-> got the Lptop to boot from USB,
-> but does does not recognice the SSD,
Best regards,
Hi ThienBui,
I5 (11th)
LC56-14T
203013-1
448.OK121.0011
Best regards,
builds3.zip
Thanks a lot for your fast support.
The patched bios shows the same symptom, get stuck during boot.
Guess I should check the HW as a next step.
Figured out the bios-files with wrong ME-section does not find the SSD but boot.
Checked the SSD HW. looks all fine ...
Measured resistance against GND, all 4 Pci lanes (SSD/CPU side) have same values,
so I assume that those are fine. 3.3V is also present,
Guess at least SSD-USB is working, because with bios-file which find the SSD the onboard diag (F11) shows SMART values.
Btw, build in (F11) Pci and MB diag are also pass.
I also checked the SSD, its booting fine on a other system.
I'd like to play around with the bios.
Could you help me with the "Flash Image Tool 15.0.1.1345"? found only version "15.0.30.1716"
Thanks,
Thanks,
please search BIOS not clearme to try
hola, necesito que me ayudes con mi bios, no da video, probe todas las bios anteriores y da video pero no reconoce el SSD interno nvme, porfavor su ayuda
2201525 .BIN
