i check to much bios but ohers bios m2 not dedect plzzz helpSo try another BIOS if you have the same problem
m2 work but same isue sound mouse and tuch not worktry file this
post bios right topic i helpHello, could you repair this file, it is freezing and generating intermittent video, Da0panmb8f0 card, thank you
Lenovo ideapad flex 5 (SN: PW00ZRMD) No display when we update vinafix bios then ssd m.2 not detect. Kindly provide correct bois.Lenovo ideapad flex 5(SNW00ZRMD), No display when we update vinafix bios then ssd m.2 not detect. Kindly provide correct bois.
Note that SSD m2 only works with the original BIOS of that laptop itself, if M2 does not detect, you need to buy a $ 35 patch to fixLenovo ideapad flex 5 (SN: PW00ZRMD) No display when we update vinafix bios then ssd m.2 not detect. Kindly provide correct bois.
203013-1 CPU i3Flex 5-14ITL05 LC56-14T
203013-1 BIOS, Schematics
Lenovo Flex 5-14ITL05 - LC56-14T 203013-1.pdf
The unit is turning on but no display, with your file I got display but SSD is not recognizing. Please fix my original bios. Thank you.
203013-1 CPU i3
Clean Me PLease
LC56-14T
203013-1
448.OK131.0011
same bios tach and mous not workingM2 need buy patch 35$
Payment link to buy Patch
mous can not check from biosmous not working
sound?mous can not check from bios
audio need buy patch 35$sound?
old bios work but no dataFlex 5-14ITL05 LC56-14T
View attachment 168747UR bios worked but hard not detected will send old bios to rebuld
