Dell Inspiron 15 Gaming 7567 BIOS LA-D993P
Motherboard LA-D993P BIOS
Dell Inspiron 14 7000 and 15 7000 Gaming System BIOS
Dell Inspiron 15 Gaming 7567 BBV00/10 LA-D993P
Schematics BBV00 BBV10 LA-D993P r1.0
boardview LAD993PR10-1110A.brd
LA-D993P BOTTOM.pdf
LA-D993P TOP.pdf
Dell Inspiron 15 Gaming 7567 - LA-D993P Boardview (.CAD).cad
Screen Shot 2020-12-03 at 17.18.51.jpgScreen Shot 2020-06-15 at 12.00.12.jpg
Clear me.BIN.zip
BBV00 BBV10 LA-D993P r1.0.pdf
LA-D993P TOP.pdf
LA-D993P BOTTOM.pdf
yes, why not Programming now ?
Will my laptop boot after this procedure?
Even when my laptop has measured and verified boot active?
I tried modifying the BIOS to unlock certain settings before, and flashing it bricked my laptop, so I had to restore a backup.
I already have HostME Regions unlocked.
Code:
Intel(R) MEInfo Version: 11.8.79.3722
Copyright(C) 2005 - 2019, Intel Corporation. All rights reserved.
Intel(R) ME code versions:
BIOS Version                                 1.11.0
MEBx Version                                 0.0.0.0000
GbE Version                                  Unknown
Vendor ID                                    8086
PCH Version                                  31
FW Version                                   11.8.70.3626 H
Security Version (SVN)                       3
LMS Version                                  2026.14.0.1682
MEI Driver Version                           2021.14.0.1615
Wireless Hardware Version                    2.1.77
Wireless Driver Version                      21.110.1.1
FW Capabilities                              0x31111140
        Intel(R) Capability Licensing Service - PRESENT/ENABLED
        Protect Audio Video Path - PRESENT/ENABLED
        Intel(R) Dynamic Application Loader - PRESENT/ENABLED
        Intel(R) Platform Trust Technology - PRESENT/ENABLED
Re-key needed                                False
Platform is re-key capable                   True
TLS                                          Disabled
Last ME reset reason                         Global system reset
Local FWUpdate                               Enabled
BIOS Config Lock                             Enabled
GbE Config Lock                              Enabled
Host Read Access to ME                       Enabled
Host Write Access to ME                      Enabled
Host Read Access to EC                       Enabled
Host Write Access to EC                      Enabled
SPI Flash ID 1                               EF4018
SPI Flash ID 2                               Unknown
BIOS boot State                              Post Boot
OEM ID                                       68853622-eed3-4e83-8a86-6cde315f6b78
Capability Licensing Service                 Enabled
OEM Tag                                      0x00000000
Slot 1 Board Manufacturer                    0x00001028
Slot 2 System Assembler                      0x00000000
Slot 3 Reserved                              0x00000000
M3 Autotest                                  Disabled
C-link Status                                Disabled
Independent Firmware Recovery                Disabled
EPID Group ID                                0x1FD9
LSPCON Ports                                 None
5K Ports                                     None
OEM Public Key Hash FPF                      0CBFCFA9742F99CDFBB2C6035B5D8BDCDA1C6BEBDF693C667A9D0E6997200A27
OEM Public Key Hash ME                       0CBFCFA9742F99CDFBB2C6035B5D8BDCDA1C6BEBDF693C667A9D0E6997200A27
ACM SVN FPF                                  0x2
KM SVN FPF                                   0x0
BSMM SVN FPF                                 0x0
GuC Encryption Key FPF                       0000000000000000000000000000000000000000000000000000000000000000
GuC Encryption Key ME                        0000000000000000000000000000000000000000000000000000000000000000
                                             FPF                      ME
Force Boot Guard ACM                         Enabled                  Enabled
Protect BIOS Environment                     Enabled                  Enabled
CPU Debugging                                Enabled                  Enabled
BSP Initialization                           Enabled                  Enabled
Measured Boot                                Enabled                  Enabled
Verified Boot                                Enabled                  Enabled
Key Manifest ID                              0xF                      0xF
Enforcement Policy                           0x3                      0x3
PTT                                          Enabled                  Enabled
PTT Lockout Override Counter                 0xA
EK Revoke State                              Revoked
PTT RTC Clear Detection FPF                  0x0
So, I do not need access to the physical chip to dump the BIOS.
Edit: I have attached the flash dump.
Please mod this bios if you can. Thanks.
File Hash
SHA256 4400CCABD7857844B4CEC38AC89FFAE425328B3D2ACC9E65805AA9526DCFFB77
FPTw_Dump.bin
Hello @ThienBui , can you verify if the FPTw Dump that I have attached above is a valid flash image?
And if yes, will you be so kind to remove the Intel ME on that image?
Thanks!
Code:
BIOS Version                                 1.11.0
GbE Version                                  Unknown
Vendor ID                                    8086
PCH Version                                  31
Re-key needed                                False
TLS                                          Disabled
OEM Tag                                      0x00000000
LSPCON Ports                                 None
5K Ports                                     None
ACM SVN FPF                                  0x2
KM SVN FPF                                   0x0
BSMM SVN FPF                                 0x0
                                             FPF                      ME
PTT                                          Enabled                  Enabled
File Hash
clear mes.zip
