BIOS Dell Inspiron 15 5583 17931-1
Inspiron 15 5583
Bolt 2SP DIS 4GB
17931-1
Y3TF7$ca
boardview
Inspiron 15 5583 17931-1_1228WZS1336.brd
17931-1 BOTTOM.pdf
17931-1 TOP.pdf
Inspiron 15 5583 17931-1 (BDV)(.CAD).cad
17931-1 test.rar
17931-1 TOP.pdf
17931-1 BOTTOM.pdf
bios gốc thì vẫn treo logo , bios a gửi lần 1 thì kích tắt, bios a gửi lần 2 thì dòng ok nhưng ko xuất hình anh ạ.
I used the wrong setting now the motherboard is set to inspiron 5584 and DVD drive not recognised..
can you fix bios for inspiron 5583 bolt 2sp dis 4gb 17931-1
i have attached my old bios
not sure form BIOS, you need try BIOS other and compare
i cant because was new motherboard when turn on first time ask for model but by mistake select
inspiron 5584 this version not have DVD...
so now even if i flash from dell support each time says inspiron 5584 in bios
but machine is inspiron 5583 DVD drive version
DVD not related to BIOS
do you have clean me for
5583 bolt 2sp dis 4gb 17931-1 y3tf7$la
why need me ?
i check both models
inspiron 5584 this 100% does not have connector for DVD drive...
inspiron 5583 this model has connector for DVD drive
I have a working machine.. DVD ok.. I just set the model of the laptop .. but by mistake, I choose model Inspiron 5584 and not Inspiron 5583 .. after I do this DVD not work..
so I check another laptop Inspiron 5584 to see the motherboard.. and the only thing I can tell was on the motherboard no DVD connector..
can not
only is info you can setup name any..
above can many BIOS want you can try more
do you have working bios for
i have tried
17931-1 test.rar
but the laptop stuck on Dell Logo .. not move
