Dell DELL E7240 LA-9431P
VAZ50 LA-9431P
REV 1.0
2013-09-11
BIOS LA-9431P E7240 A29 Test ok
Schematic DELL E7240 VAZ50 LA-9431P
MODEL NAME : VAZ50
PCB NO : LA-9431P (DAA00005Z10)
BOM P/N : 4319LL31LXX
GPIO MAP: 3.0C
Goliad 12"
Haswell ULT
2013-05-17
REV : 1.0 (A00)
Schematics LA9431P R10-0516.cad
BIOS Dell Latitude E7240 LA-9431P i7
boardview
LA9431PR10-0516.brd
LA-9431P TOP.pdf
LA-9431P BOTTOM.pdf
I do not understand what you encounter errors ?
I use TL866 and Xeltek SuperPro 610P
I have problems ..because if you can see the picture .. i`m missing some details of my chip. According to the data sheet ..i have the chip : W25X10CLSNIG _SO8, but when i connect to my device ..as you can see in the picture i`m missing the SNIG _SO8, and to be honest i don`t know if it counts or not. But it does flash it and seems to be properly programmed ...but still doesn`t work :).
in photo i see W25Q64xx....
You need find chip W25X10CLxxx...
two completely different chip, you need to find the right chips salary space or Programming your machine does not support chip this.
Finally, here is the working dump for boards with U1 chip only, after I remove the password, the custom logo and update it to the latest version A15.
For more BIOS'es problems you can always contact me at [email protected] or [email protected]
Tested and works 100%. Same as new.
Enjoy :D
Thanks buddy ... your bios work for my job .. i had also done my job with password problem
