NBPC1958
GD25LQ64B@SOP8-200_20230927_111556.BIN
You need check AMD chipGreetings Master ThienBui
I need your help with this laptop. I check all voltages normally. problem is no display i would to repair or build this bios flash files first
here are the laptop model and bios Files. Thanks
Coby Model: NBPC1958
Please ask your customer to provide the bios file he uses to update so I can checkMaster ThienBui. if you like only to build or repair these bios i request. i wondered bcoz the customer told to me after the update windows, she was forced to turn it off after that. it is now happening?
my customer only needs to fix her coby laptop. come to my shop. I asked some questions about what happened before this no-display. She told me that after using. she decide to turn of the appeared windows update. long time . she decide to force turn off. off topic( my costumer she didn't know the bios or technical ) now i give the Bios backup attech kindly try to rebuild or repair. Thank youPlease ask your customer to provide the bios file he uses to update so I can check
I said this laptop uses AMD CPU without builds or clearme if you can download the bios update from the page then I will help checkmy customer only needs to fix her coby laptop. come to my shop. I asked some questions about what happened before this no-display. She told me that after using. she decide to turn of the appeared windows update. long time . she decide to force turn off. off topic( my costumer she didn't know the bios or technical ) now i give the Bios backup attech kindly try to rebuild or repair. Thank you
Thank you. can you provide me any ver of bios for this Coby laptop model?I said this laptop uses AMD CPU without builds or clearme if you can download the bios update from the page then I will help check
hi sir
pls fixmybios.remove splash screen
Unavailablehi,I need boardview for this
COBY EM_AP619_V3.0 NBPC1958.thanks
