ASUS ZenBook Pro UX501VW
6th Gen Intel Core i
  • Processor
    Intel® Core™ i7 6700HQ Processor,
  • Operating System
    Windows 10 Home
    Windows 10 Pro
  • Chipset
    Intel® HM170 Chipset
  • Memory
    DDR4 2133 MHz SDRAM, up to 16 G, OnBoard Memory 8 GB , 1x DIMM socket
  • Display
    15.6" 16:9 IPS UHD (3840 x 2160)/IPS FHD (1920x1080) Asus Splendid Video Intelligent Technology, Zero Bright Dot
  • Graphic
    NVIDIA® GeForce® GTX 960M with 2G/4G GDDR5 VRAM
  • Storage
    2.5" 7mm SATA3
    - 1TB HDD 5400 RPM
    - 128GB SSD
    - 256GB SSD
    PCIE x 4 512G
  • Card Reader
    2 -in-1 card reader ( SD/ SDXC/ MMC)
  • Camera
    HD Web Camera
  • Networking
    Integrated 802.11 b/g/n or 802.11 ac
    Built-in Bluetooth™ V4.0
    10/100 Base T
  • Interface
    1 x Microphone-in/Headphone-out jack
    1 x USB 3.1 TYPE C port(s)
    3 x USB 3.0 port(s)
    1 x HDMI
    1 x Thunderbolt port
  • Audio
    Built-in Stereo W Speakers And Array Microphone
    Bang & Olufsen
    Support Windows 10 Cortana with Voice
  • Battery
    96 Whrs
    60 Whrs
  • Power Adapter
    Plug Type :ø4.5 (mm)
    Output :
    19 V DC, 6.32 A,
    Input :
  • Dimensions
    383 x 255 x 20.6 ~21.3 mm (WxDxH)
  • Weight
    2.06 kg with Battery
  • Certificates
    UL, TUV, FCC Compliance, BSMI, Australia C-TICK / NZ A-Tick Compliance, CCC, CB, Energy star, RoHS, JATE
  • Only for Search
    Thinnes - Laptop
UX501VW 2.0.BIN.zip
Asus N501VW_RG.pdf
You're right, it's not the EC. This is the scouting program U1201. I am trying to figure out why the touchpad and keyboard backlighting are not working. The backlight has already started working after using bt2.exe bt -c cnfg / w dd 7c but unfortunately the touchpad still does not work. It is not in the device manager after the Bios update. I replaced the KBC, programmed the BIOS with dozens of batches and still a failure ...
