Asus ROG GL502VM
Asus ROG GL502VM
ZX60V GL502VM REV 2.0
Asus GL502VM r2.0 boardview.fz
ASUS ROG GL502VM REV2.0.pdf
  • Processor
    Intel® Core™ i7 6700HQ Processor,
    Intel® Core™ i5 6300HQ Processor,
  • Operating System
    Windows 10 Home
    Windows 10 Pro
  • Chipset
    Intel® HM170 Chipset
  • Memory
    8 GB DDR4 2133MHz SDRAM Onboard Memory, 1 x SO-DIMM socket for expansion, up to 16 GB SDRAM
  • Display
    15.6" (16:9) LED backlit UHD (3840x2160) 60Hz Anit-Glaire Panel with 72% NTSC with G-Sync
    15.6" (16:9) LED backlit FHD (1920x1080) 60Hz Anit-Glaire Panel with 72% NTSC with G-Sync
    With WideView Technology
  • Graphic
    NVIDIA GeForce GTX 1060 , with GDDR53GB/6GB VRAM
  • Storage
    Hard Drives:
    1TB 5400RPM SATA HDD
    1TB 7200RPM SATA HDD
    Solid State Drives:
    128GB/256GB/512GB SATA3 SSD
    Solid State Drives:
    256GB/512GB PCIE Gen3X4 SSD
  • Keyboard
    Illuminated Chiclet Keyboard
  • Card Reader
    Multi-format card reader (SDHC/SDXC/MMC)
  • WebCam
    HD Web Camera
  • Networking
    Wi-Fi
    Integrated 802.11b/g/n
    Integrated 802.11 AC
    Bluetooth
    Built-in Bluetooth V4.0
  • Interface
    1 x Microphone-in/Headphone-out jack
    1 x USB 3.1 TYPE C port(s)
    3 x USB 3.0 port(s)
    1 x HDMI
    1 x mini Display Port
    1X AC adapter plug
  • Audio
    Support Windows 10 Cortana with Voice
    ASUS SonicMaster Technology
  • Battery
    4 Cells Battery
  • Power Adapter
    Plug Type :ø5.5 (mm)
    Output :
    19.5 V DC, 9.23 A, 180 W
    Input :
  • Dimensions
    Tablet:
    390 x 266 x 23.5 mm (WxDxH)
  • Weight
    2.2 kg with Battery
  • Security
    Kensington lock
  • Certificates
    UL, TUV, CE Marking Compliance, FCC Compliance, BSMI, Australia C-TICK / NZ A-Tick Compliance, CCC, GOST-R, CB, Energy star, WEEE, RoHS
  • Manufacturer Warranty
GL502VM REV 2.1
ASUS FX60V FX60VM I7-7700HQ 8G GTX1060 6G
GL502VM KB_pins=30 LEFT DOWN FLASH=56 PD0=29 PD1=20 PD2=15 PD3=23 PD4=14 PD5=16 PD6=12 PD7=30 BUSY=26 STB=18 AFD=28 INIT=21 SLIN=19 KSI4=22 KSI5=24 IT8171Screen Shot 2019-10-26 at 12.02.47 PM.jpg
Sorry to bother you, but the bbbb.zip dump you sent me is the same as my original dump, I compared them. It makes no difference. How can this help me?
that shows BIOS no problem next need to check the hardware.
Thanks, I also suspected the hardware but wanted your confirmation. I suspect the built-in memory, but I'm not sure if it can be turned off on this model. Thanks again, your help means a lot to me. I wish you a pleasant day!
When you say IO Check are you reffering to U3502? EMBEDDED CONTR IT8171FN-56
nop the EC that he advise is not ok for this EC controler ... he keeps arguing he send good EC for this machine but he doesn't . the correct EC for the IT8171FN is the one that im sending now ... and not the cuted size he offer to people !!!!
