Asus ROG GL502VM
Asus ROG GL502VM
ZX60V GL502VM REV 2.0
Asus GL502VM r2.0 boardview.fz
ASUS ROG GL502VM REV2.0.pdf
  • Processor
    Intel® Core™ i7 6700HQ Processor,
    Intel® Core™ i5 6300HQ Processor,
  • Operating System
    Windows 10 Home
    Windows 10 Pro
  • Chipset
    Intel® HM170 Chipset
  • Memory
    8 GB DDR4 2133MHz SDRAM Onboard Memory, 1 x SO-DIMM socket for expansion, up to 16 GB SDRAM
  • Display
    15.6" (16:9) LED backlit UHD (3840x2160) 60Hz Anit-Glaire Panel with 72% NTSC with G-Sync
    15.6" (16:9) LED backlit FHD (1920x1080) 60Hz Anit-Glaire Panel with 72% NTSC with G-Sync
    With WideView Technology
  • Graphic
    NVIDIA GeForce GTX 1060 , with GDDR53GB/6GB VRAM
  • Storage
    Hard Drives:
    1TB 5400RPM SATA HDD
    1TB 7200RPM SATA HDD
    Solid State Drives:
    128GB/256GB/512GB SATA3 SSD
    Solid State Drives:
    256GB/512GB PCIE Gen3X4 SSD
  • Keyboard
    Illuminated Chiclet Keyboard
  • Card Reader
    Multi-format card reader (SDHC/SDXC/MMC)
  • WebCam
    HD Web Camera
  • Networking
    Wi-Fi
    Integrated 802.11b/g/n
    Integrated 802.11 AC
    Bluetooth
    Built-in Bluetooth V4.0
  • Interface
    1 x Microphone-in/Headphone-out jack
    1 x USB 3.1 TYPE C port(s)
    3 x USB 3.0 port(s)
    1 x HDMI
    1 x mini Display Port
    1X AC adapter plug
  • Audio
    Support Windows 10 Cortana with Voice
    ASUS SonicMaster Technology
  • Battery
    4 Cells Battery
  • Power Adapter
    Plug Type :ø5.5 (mm)
    Output :
    19.5 V DC, 9.23 A, 180 W
    Input :
  • Dimensions
    Tablet:
    390 x 266 x 23.5 mm (WxDxH)
  • Weight
    2.2 kg with Battery
  • Security
    Kensington lock
  • Certificates
    UL, TUV, CE Marking Compliance, FCC Compliance, BSMI, Australia C-TICK / NZ A-Tick Compliance, CCC, GOST-R, CB, Energy star, WEEE, RoHS
  • Manufacturer Warranty
GL502VM REV 2.1
ASUS FX60V FX60VM I7-7700HQ 8G GTX1060 6G
GL502VM KB_pins=30 LEFT DOWN FLASH=56 PD0=29 PD1=20 PD2=15 PD3=23 PD4=14 PD5=16 PD6=12 PD7=30 BUSY=26 STB=18 AFD=28 INIT=21 SLIN=19 KSI4=22 KSI5=24 IT8171Screen Shot 2019-10-26 at 12.02.47 PM.jpg
FX60VM GL502VM REV 2.1.BIN.zip
ZX60V GL502VM REV 2.0.202.bin
GL502VM ECROM.bin
GL502VM r2.1 SKL.pdf
W25Q80(8K BIT OTP)_ASUS GL502VM.zip
Dear friend, I have a laptop Asus Rog GL502VM Rev: 2.0. The logo appears about 15 seconds after I press the button. The laptop restarts periodically. The laptop does not heat up, it has been cleaned of dust, the thermal paste has been replaced. Can you help me? I am sending you pictures of the motherboard and the original dumps. Thank you!
need try one BIOS and check hardware
It's not relevant to wipe the thermal paste.
Okay, thanks, I'll try. Did you get the dumps I uploaded? Maybe the ME Region needs to be cleaned? But I will definitely try your bios first.
BIOS clearme above also has a lot, I think there are more important things than clearme, you only care about clearme when you see delay display
Display delay is about 15 seconds. I'll try your dumps, I'll get back to you after that. Thank you!
I tried all your dumps but no success. No indication, no power. With the original dumps, the laptop turns on, works normally, but restarts. The display is delayed by about 15 seconds. No help?
that shows BIOS can't fail, all BIOS can't have the same error
Your dumps do not help me, no power, there is no indication at all when I connect the ac adapter. I sent you my original dumps. Display delay of 15 seconds and restarts. Did you get my dumps, are they ok? I can send them again.
