N53SV Rev 2.2
HM65
Ver: 214
HM65
Ver: 214
N53SV_214.rar
i downloaded this file but with password!
n53sv rev 2.0 nvidia n12p-gt-a1 corei7
please help me!
Programming one BIOS other.Same here how did yopu solved ?
Bios clear me for: N53SV 2.0
Please thx
CLEAR ME PLS.
no screen clean please
I think hardware have problemHello, having a strange problem with a N53SV Rev2.2. With the power connection, it works fine. If i remove the power, and leave it on battery, it works for some time. It varies, but when it lowers from the 50% battery, it just shuts down on battery. Try to trun it on, and it turns off again. There is a sudden loss of power in the conection from the battery to the board, in the main volt entry and in the 3V conectors... any ideia what could be causing this situation?
Any idea on where i could look? I already tried with two batteries and the problem persists. I have been looking in the schematics of the board, and there is one point that i have no power. In PD6001, the 6th pin has no power whatsoever. Its the one that connects to the N140593235 connector on the battery, should it have some voltage here?I think hardware have problem
if other BIOS has the same problem it will not be possible to repair from biosAny idea on where i could look? I already tried with two batteries and the problem persists. I have been looking in the schematics of the board, and there is one point that i have no power. In PD6001, the 6th pin has no power whatsoever. Its the one that connects to the N140593235 connector on the battery, should it have some voltage here?
I did try your bios but wifi and lan doesn't work so please fix my bios has no display problem
