BIOS ASUS N3050T
ASUS N3050T
BIOS N3050T-SI-0402
  • CPU
    Intel® Celeron® Dual-Core N3050 SoC onboard Processors
  • Memory
    2 x SO-DIMM, Max. 8GB, DDR3 1600/1066 MHz Non-ECC, Un-buffered Memory *1
  • Graphic
    Integrated Graphics Processor
    Multi-VGA output support : HDMI/RGB/LVDS ports
    - Supports HDMI with max. resolution 3840 x 2160 @ 30 Hz
    - Supports LVDS with max. resolution 1920 x 1200 @ 60 Hz
    Supports up to 3 displays simultaneously
  • Expansion Slots
    1 x mini-PCIe (full-length)
    1 x mini-PCIe (half-length)
  • Storage
    2 x SATA 6Gb/s port(s),
    1 x mini-SATA 6Gb/s port(s)*2,
  • LAN
    Realtek® RTL8111H, 1 x Gigabit LAN Controller(s)
  • Audio
    Realtek® ALC887-VD2 8-Channel High Definition Audio CODEC
    - Supports : Jack-detection, Front Panel Jack-retasking
  • USB Ports
    Built-in Controller :
    4 x USB 3.0 port(s) (4 at back panel, )
    GL852G USB Hub :
    5 x USB 2.0 port(s) (5 at mid-board)
  • Special Features
    ASUS 5X Protection :
    - ASUS LANGuard - Advanced LAN protection
    - ASUS Enhanced DRAM Overcurrent Protection - Short circuit damage prevention
    - ASUS ESD Guards - Enhanced ESD protection
    - ASUS High-Quality 5K-Hour Solid Capacitors - 2.5x long lifespan with excellent durability
    - ASUS Stainless Steel Back I/O - 3x more durable corrosion-resistant coating
    ASUS Exclusive Features :
    - AI Suite 3
    - Ai Charger
    - USB 3.0 Boost
    - Mobo Connect
    ASUS Quiet Thermal Solution :
    - ASUS Fan Xpert
    ASUS EZ DIY :
    - ASUS CrashFree BIOS 3
    - ASUS EZ Flash 3
    - Push Notice
    100% All High-quality Conductive Polymer Capacitors
    Media Streamer
  • Operating System Support
    Windows® 10 , 64bit
    Windows® 8.1 , 64bit
    Windows® 7 , 64bit
  • Back I/O Ports
    1 x D-Sub
    1 x HDMI
    1 x LAN (RJ45) port(s)
    4 x USB 3.0
    2 x Audio jack(s)
    1 x DC power connector(s)
  • Internal I/O Ports
    3 x USB 2.0 connector(s) support(s) additional 5 USB 2.0 port(s)
    1 x COM port(s) connector(s)
    2 x SATA 6Gb/s connector(s)
    1 x SATA power connector(s)
    1 x mSATA connector
    1 x Chassis Fan connector(s) (1 x 4 -pin)
    1 x Internal speaker connector(s)
    1 x Chassis Intrusion connector(s)
    1 x 2-pin internal DC power connector
    1 x Stereo speaker connector
    1 x DMIC header
    1 x LVDS connector(s)
    1 x 14-1 pin TPM connector
    1 x System panel connector
    1 x Display panel backlight power selector
    1 x Flat panel display brightness connector
    1 x Display panel VCC power selector
    1 x LCD panel monitor switch header
  • Accessories
    User's manual
    I/O Shield
    Thin Mini ITX I/O Shield
    1 x SATA power cable
    2 x SATA 6Gb/s cable(s)
    1 x Mini PCIe Screw Package
  • BIOS
    64 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.8, ACPI 5.0, Multi-language BIOS, ASUS EZ Flash 3, ASUS CrashFree BIOS 3, My Favorites, Quick Note, Last Modified log, F12 PrintScreen, F3 Shortcut functions and ASUS DRAM SPD (Serial Presence Detect) memory information
  • Manageability
    WfM 2.0, DMI 2.0, WOL by PME, PXE
  • Support Disc
    Drivers
    ASUS Utilities
    EZ Update
  • Form Factor
    Thin Mini ITX Form Factor
    6.7 inch x 6.7 inch ( 17 cm x 17 cm )
  • Note
    *1 Support both 1.35V DDR3L and 1.5V DDR3
    *2 mSATA shares the same slot with the full-length mini-PCIe card. mSATA shares the same bandwidth with SATA6G_2 slot. When a device is installed on the SATA6G_2 slot, the mSATA device is disabled.
    *DC in connector dimension: 7.4 x 5.1mm, Support both 19V and 12V DC input
N3050T-SI-0402.BIN.zip
