ASUS A441U X441UV REV 2.1
ASUS VivoBook Max X441UV
  • Processor
  • Operating System
    Windows 10 Home
    Windows 10 Pro
  • Chipset
    Integrated Intel® CPU
  • Memory
    , 1 x SO-DIMM socket , up to 16 GB SDRAM(On selected models)
  • Display
    14.0" (16:9) LED backlit HD (1366x768) Glare Panel with 45% NTSC
    14.0" (16:9) LED backlit FHD (1600x900) Glare Panel with 45% NTSC
    Support ASUS Splendid Technology
  • Graphic
    NVIDIA GeForce 920MX , with 1GB VRAM
  • Storage
    Hard Drives:
    500GB 5400RPM SATA HDD
    1TB 5400RPM SATA HDD
    2TB 5400RPM SATA HDD
  • Optical Drive
    Super-Multi DVD
  • Keyboard
    Chicklet keyboard
  • Card Reader
    Multi-format card reader (SD/SDHC)
  • WebCam
    VGA Web Camera
  • Networking
    Wi-Fi
    Integrated 802.11b/g/n
    Integrated 802.11 AC
    Bluetooth
    Built-in Bluetooth V4.0
  • Interface
    1 x COMBO audio jack
    1 x VGA port
    1 x USB 3.0 port(s)
    1 x USB 2.0 port(s)
    1 x HDMI
    1X AC adapter plug
  • Audio
    ASUS SonicMaster Technology
  • Battery
    36 Whrs Battery
  • Power Adapter
    Plug Type :ø4 (mm)
    Output :
    19 V DC, 2.47 A, 45 W
    Input :
  • Dimensions
    348 x 242 x 27.6 ~ mm (WxDxH)
  • Weight
    1.75 kg with Battery
F441U I5-7200U 4G X441UV Rev 2.1
A441U.BIN.zip
X441UV ECROM ENE.bin
X441UV MB.fz
clear me X441UV.bin
Edit help e không hiển thị
đã thủ bios trên vẫn vậy
phải xem nó có bị lỗi do bios ko chứ đâu phải cứ nạp bios hay sửa bios là dc bạn
nếu nạp 1 hai bios khác mà kết quả như nhau thì phần lớn là ko phải do bios
Need bios X441UV REV. 2.1 Intel® Core™ i3 6100U Processor, Disable RAM. I don't have the original BIOS because the BIOS chip is damaged.
