Edit Serial can solve this problem ?Very Slow Performance and Fan Spin Speed So high
Thing i have done
Data Trasnfer cable changed , Converts HDD to SSD
i will do Clean me region by selfif you have any suggestion please tell
Thanks
plc remove password
plc remove password
on top Available820-3115-b need board view
please remove password apple 820-3115-b
sorry not Understandsir this bios very slo process and I install os Catalina now not install os hi Sierra
No display ?Hi guys,
i got this 820-3115 that I can´t get to boot.
Change the SMC because light was orange all the time. Someone messed with it before.
It has green light without battery and orange with battery.
Starts and chimes, Caps Lock gets green, Backlight is ok. no picture on external Monitor.
But it stops there. Looks like the keyboard got some water an is shorted. i tried a different topcase but no change.
Updated clean EFI and did NVRAM reset.
Is 5.6 Ohms a normal value for PP1V05_S0 ?
Anything else i can check?
No display ?
i think you need check hardwareNothing. Backlight goes on. Tried to get into Recovery or anything but also nothing.
External Monitor does nothing either.
what do you mean?i think you need check hardware
