ACER ASPIRE E5-573 MODEL N15Q1 BIOS NEED
imranroni here is it the file , let me know , all the best :)
edit i even tryed making the new region on it , but same issue :) if you fix your´´re a boss :D eheh
hi friend this bios is from, acer aspire e5-573 can give me full model and motherboard code
then i try to repair it for you
with my bios following pat signal all seem ok and starting on correct time (at least during the time it mantain ON ) i guess perhaps issues with CPU_/PCH unit (noticed now that without memory machines stay always ON , so anything can be wrong between memory controler of cpu or anything around that , will spend more time on it but im so full of work here :| guess im going to put her on the side a bit , but strange with my bios it turn on for sure and nice amp consume ,, but with your or latest from thien are not making the machine to turn on
yes some bios here not work correctly other works ok
any way strange issue need more time and be patient my friend
regards.
yeah this work requires tons of patience ehehheeh , but becomes hard when you have a rate of 20 machines per day coming to the lab :/
