u means password file,i do this machine on continouslyreturm old and check again
right you need returm file old have password you send me above.u means password file,i do this machine on continously
wow, BIOS is not related to the diagram or boardview.thanks, I have Hexeditor.. But i only get alot of numbers.. NO Schematic or no boardview??
'.bin' files are what the BIOS is stored in. So the schematics will never be in a bin file, but the dump from the BIOS ROM will be.Im not talking about any BIOS.. The BIN.file... which is the extension on your zip files. Doesnt work or your files are corrput. It doenst work to open the schematics or the boardview for 820-000426... Try open it yourself, have u done that? It doesnt work..
https://vinafix.com/threads/820-00163-a-a1398.17530/Use 820-00163, it is almost the same.
Almost the same is nt good enough. Need the proper one. No problem I will buy it from another website.. costs only 30 Usd..Use 820-00163, it is almost the same.
con này chưa thấy schematic hay boardview luôn.e cần boardview 820-00426
Available herewhy you don't have one it seem that the most website has this boardview
You need to reinstall the previous OS version to identify problems due to WiFi card or MacOSHi everyone i have a strange problem,
Wi-fi can not turn on after upgrade cataline Macbook pro 15" 2015 820-00426-a
After upgraded Cataline OS Wifi stop to working all hardware test ok also i can see in details wifi hardware but still can not turn on,
when i am hold on alt button still can not see any wifi connection, just one time random its worked but after restart gone again.
* I changed Wi-fi card 2 times.
* I tried to downgrade i installed high siearra also majavo
* I tried diffrent bios dump,
* i tried to clear ME
* i tried internet recovery (via ethernet)
* i tried to delete osx wifi profiles also plist files.
*PS no water damage, or drop.
is there any idea?
Thanks everyone..
thanks for your advice but i aldready did and wrote i tried mojavo also high sierra via internet recovery. nothing changed.You need to reinstall the previous OS version to identify problems due to WiFi card or MacOS
