Clevo 6-71-W24E0-D03 GP DNS 0801189 ( W244EUMB-B )
There are 2 chips as you can see from the attached photos. I clamp the chip, try to read the chip and it tells me there is a short circuit. Do the chips need to be unsoldered from the motherboard? I tried soldered chips.
Beyond this I also tried to power the fan with the 5Vs of the motherboard so as to always remain on, but the pc turns off the same. I believe at this point it is a hardware problem.
Too bad because it was a good pc !!!
you can remove chip and read. If not, you need to replace another chip or programming tool
