Dell Latitude 7480 BIOS CAZ20 LA-E131P Rev: 1.0 (A00) Schematics BIOS
BIOS 25Q128FV 6th
boardview Dell Latitude 7480 - LA-E131P Boardview (.CAD).cad
Schematics
LA-E131P BOTTOM.pdf
LA-E131P TOP.pdf
Screen Shot 2020-07-08 at 15.41.22.jpgScreen Shot 2020-12-06 at 22.15.06.jpg
clear me la-e131p.bin.zip
LA-E131P.pdf
LA-E131P BOTTOM.pdf
LA-E131P TOP.pdf
UT2.bin.zip
1MB.BIN.zip
i updated original BIOS for you
after clear ME problem was still the same, laptop was working, but cant install LAN driver
after that we tried BIOS from other E7480 without changing ME Region, just original BIOS from other laptop, same model and LAN was working fine, but laptop needs 30 seconds more to boot. We need working LAN and normal speed of booting. Can you help?
You helped me with this in this E7470 thread:
E7470
the problem is identical
E7470
Please not clear me
I will help later
Programming bios this and send i rssult
note not ask many, i need result
Uploading the bios:
Latitude 7480 CAZ20 LA-E132P BIOS 25Q128FV BF
makes the LAN card detected correctly but appears BSOD:
whea uncorrectable error
however, when the bios is uploaded:
GD25Q128B@WSON8_20210107_83606
there is no problem with the bsod, but the network card is no longer detected (LAN)
Please make note of the BIOS file you want to fix
