Asus Z170I PRO GAMING
ASUS Z170I PRO GAMING
BIOS Z170I-PRO-GAMING-ASUS-0401
Miniaturized size, maximized gaming fun
  • LGA1151 socket for 6th-gen Intel® Core™ i7 / Core i5 / Core i3, Pentium® and Celeron Processors
  • Dual DDR4 4000 (OC) support
  • SupremeFX: Flawless audio that makes you part of the game
  • Sonic Radar ll: Scan and detect your enemies to dominate
  • Intel Gigabit Ethernet, LANGuard and GameFirst technologies: Top-speed protected networking
  • 5-Way Optimization and Pro Clock technology: Easy and stable overclocking
  • RAMCache: Speed up your game loads
  • Gamer's Guardian: Highly-durable components and smart DIY features
  • 2x2 Wi-Fi with MU-MIMO, USB 3.1 Type-A and M.2: Ultra-speedy transfers for faster gaming
  • CPU
    Supports Intel® 14 nm CPU
  • Chipset
    Intel® Z170
  • Memory
    2 x DIMM, Max. 32GB, DDR4 3400(O.C.)/3333(O.C.)/3200(O.C.)/3100(O.C.)/3000(O.C.)/2933(O.C.)/2800(O.C.)/2666(O.C.)/2600(O.C.)/2400(O.C.)/2133 MHz Non-ECC, Un-buffered Memory
  • Graphic
    Multi-VGA output support : HDMI/DisplayPort ports
    - Supports HDMI with max. resolution 4096 x 2160 @ 24 Hz
    - Supports DisplayPort with max. resolution 4096 x 2304 @ 60 Hz
  • Expansion Slots
    1 x PCIe 3.0/2.0 x16
  • Storage
    Support Raid 0, 1, 5, 10
    Intel® Rapid Storage Technology supports
    1 x SATA Express port, Compatible with 2 x SATA 6.0 Gb/s ports
    1 x M.2 Socket 3, with M key, type 2242/2260/2280 storage devices support (both SATA & PCIE mode)*1
    2 x SATA 6Gb/s port(s)
    Supports Intel® Smart Response Technology*2
  • LAN
    Intel® I219V, 1 x Gigabit LAN Controller(s), GameFirst technology
    Anti-surge LANGuard
  • Wireless Data Network
    Wi-Fi 802.11 a/b/g/n/ac
    Supports dual band frequency 2.4/5 GHz
    Support ASUS Wi-Fi Go! Utility
  • Bluetooth
    Bluetooth V4.1
  • Audio
    SupremeFX 8-Channel High Definition Audio CODEC
    - Supports : Jack-detection, Multi-streaming, Front Panel MIC Jack-retasking
    - High quality 115 dB SNR stereo playback output
    Audio Feature :
    - SupremeFX Shielding™ Technology
    - Sonic Radar II
  • USB Ports
    ASMedia® USB 3.1 controller :
    2 x USB 3.1 port(s) (Type-A)
    Intel® Z170 chipset :
    6 x USB 3.0/2.0 port(s) (4 at back panel, blue, 2 at mid-board)
    4 x USB 2.0/1.1 port(s) (2 at back panel, black, 2 at mid-board)
  • Special Features
    ASUS Dual Intelligent Processors 5-Way Optimization by Dual Intelligent Processors 5 :
    - 5-Way Optimization tuning key perfectly consolidates TPU, EPU, DIGI+ VRM, Fan Xpert 2+, and Turbo App
    Gamer's Guardian:
    - ESD Guards on LAN, Audio, KBMS and USB3.0/2.0 ports
    - DRAM Overcurrent Protection
    - Stainless Steel Back I/O
    - Highly Durable Components
    - DIGI+ VRM
    ASUS TPU :
    - Auto Tuning
    - TurboV
    - GPU Boost
    ASUS EPU :
    - EPU
    ASUS Exclusive Features :
    - AI Suite 3
    - Ai Charger+
    - USB 3.1 Boost
    - Disk Unlocker
    ASUS Quiet Thermal Solution :
    - ASUS Fan Xpert 2+
    ASUS EZ DIY :
    - ASUS CrashFree BIOS 3
    - ASUS EZ Flash 3
    - Push Notice
    ASUS Q-Design :
    - ASUS Q-Shield
    - ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
    - ASUS Q-DIMM
    - ASUS Q-Connector
    Media Streamer
    RAMCache
  • Operating System Support
    Windows® 10 , 64bit
    Windows® 8.1 , 64bit
    Windows® 7 , 32bit/64bit
  • Back I/O Ports
    1 x DisplayPort
    1 x HDMI
    1 x LAN (RJ45) port(s)
    2 x USB 3.1 (red)Type-A
    4 x USB 3.0
    2 x USB 2.0
    1 x Optical S/PDIF out
    5 x Audio jack(s)
    2 x Wi-Fi antenna port(s)
  • Internal I/O Ports
    1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin)
    1 x USB 2.0 connector(s) support(s) additional 2 USB 2.0 port(s)
    1 x SATA Express connector: gray, Compatible with 2 x SATA 6.0 Gb/s ports
    1 x M.2 Socket 3 with M Key design, type 2242/2260/2280 storage devices support (Supports both SATA & PCIE SSD)
    2 x SATA 6Gb/s connector(s)
    1 x System panel(s)
    1 x Clear CMOS jumper(s)
    1 x 14-1 pin TPM connector
  • Accessories
    User's manual
    ASUS Q-Shield
    M.2 2242 mounting kit
    4 x SATA 6Gb/s cable(s)
    1 x M.2 Screw Package
    1 x CPU installation tool
    1 x Supporting DVD
    1 x 12 in 1 Cable Label (s)
  • BIOS
    128 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI3.0, WfM2.0, SM BIOS 3.0 ACPI 5.0, Multi-language BIOS,
    ASUS EZ Flash 3, CrashFree BIOS 3, F11 EZ Tuning Wizard, F6 Qfan Control, F3 My Favorites, Quick Note, Last Modified log, F12 PrintScreen, and ASUS DRAM SPD (Serial Presence Detect) memory information
  • Manageability
  • Support Disc
    Drivers
    ASUS Utilities
    ASUS EZ Update
  • Form Factor
    Mini ITX Form Factor
    6.7 inch x 6.7 inch ( 17 cm x 17 cm )
  • Note
    *1:For a 2242 storage device, use the bundled 2242 mounting kit.
    *2:These functions will work depending on the CPU installed.
ASUS Z170I Pro Gaming REV1.04.fz
ASUS Z170I Pro Gaming REV1.05.fz
Asus Z170I-PRO-GAMING RG.pdf
boardview
Z170I-PRO-GAMING-ASUS-0401.BIN.zip
ASUS Z170I Pro Gaming REV1.04.fz.zip
ASUS Z170I Pro Gaming REV1.05.fz.zip
