Asus Z170-DELUXE
Z170-DELUXE BIOS
Z170-DELUXE-ASUS-1101 16MB
5-Way Optimization: One click optimizes your entire system with a dedicated water-pump header on board
ASUS Pro Clock Technology: Extends base clocks and improves stability for extreme overclocking
6 USB 3.1 onboard: 5 Type-A ports and 1 reversible Type-C port
Dual 32Gbit/s ultra-fast M.2 x4: Onboard and PCIe add-in card
Hyper Kit: Bundled for instant U.2 support
  • CPU
    Supports Intel® 14 nm CPU
    * Refer to www.asus.com for CPU support list
  • Chipset
    Intel® Z170
  • Memory
    4 x DIMM, Max. 64GB, DDR4 3733(O.C.)/3600(O.C.)/3466(O.C.)/3400(O.C.)/3333(O.C.)/3300(O.C.)/3200(O.C.)/3000(O.C.)/2800(O.C.)/2666(O.C.)/2400(O.C.)/2133 MHz Non-ECC, Un-buffered Memory
  • Graphic
    Multi-VGA output support : HDMI/DisplayPort ports
    - Supports HDMI with max. resolution 4096 x 2160 @ 24 Hz / 4096 x 2160 @ 60 Hz
    - Supports DisplayPort with max. resolution 4096 x 2304 @ 24 Hz / 4096 x 2304 @ 60 Hz
    Supports up to 2 displays simultaneously
    DP 1.2 Multi-Stream Transport compliant, supports DP 1.2 monitor daisy chain up to 3 displays
  • Multi-GPU Support
    Supports NVIDIA® Quad-GPU SLI™ Technology
    Supports NVIDIA® 2-Way SLI™ Technology
    Supports AMD 3-Way CrossFireX™ Technology
  • Expansion Slots
    2 x PCIe 3.0/2.0 x16 (x16 or dual x8)
    1 x PCIe 3.0/2.0 x16 (max at x4 mode) *1
    4 x PCIe x1
  • Storage
    Intel® Z170 chipset :
    1 x SATA Express port, Compatible with 2 x SATA 6.0 Gb/s ports
    1 x M.2 x4 Socket 3, with M Key, type 2242/2260/2280/22110 storage devices support (both SATA & PCIE mode)*2
    6 x SATA 6Gb/s port(s), gray
    Support Raid 0, 1, 5, 10
    Intel® Rapid Storage Technology supports*3
    Supports Intel® Smart Response Technology*4
    ASMedia® SATA 6Gb/s controller : *5
    2 x SATA 6Gb/s port(s), black,
  • LAN
    Intel® I219V, 1 x Gigabit LAN Controller(s)
    Intel® I211-AT, 1 x Gigabit LAN
    Gigabit Intel® LAN Connection- 802.3az Energy Efficient Ethernet (EEE) appliance
    ASUS Turbo LAN Utility
    ASUS LAN Guard
  • Wireless Data Network
    Wi-Fi 802.11 a/b/g/n/ac
    Supports dual band frequency 2.4/5 GHz
    Support ASUS Wi-Fi Go! Utility
    Up to 1300Mbps transfer speed
  • Bluetooth
    Bluetooth V4.0
  • Audio
    Realtek® ALC1150 8-Channel High Definition Audio CODEC featuring Crystal Sound 3
    - Supports : Multi-streaming, Front Panel MIC Jack-retasking
    - High quality 112 dB SNR stereo playback output (Line-out at rear) and 104 dB SNR recording input (Line-in)
    Audio Feature :
    - DTS Connect
    - DTS Studio Sound
    - BD Audio Layer Content Protection
    - Audio amplifier: Provides the highest-quality sound for headphone and speakers
    - Unique de-pop circuit: Reduces start-up popping noise to audio outputs
    - Top notch audio sensation delivers according to the audio configuration
    - Absolute Pitch 192khz/24bit true BD lossless sound
    Separate layer for left and right track, ensuring both sound deliver equal quality
  • USB Ports
    5 x USB 3.0/2.0 port(s) (1 at back panel, blue, Type-A, 4 at mid-board)
    5 x USB 2.0/1.1 port(s) (1 at back panel, black, Type-A, 4 at mid-board)
    ASMedia® USB 3.1 controller :
    5 x USB 3.1/3.0/2.0 port(s) (5 at back panel, teal blue, Type-A)
    1 x USB 3.1/3.0/2.0 port(s) (1 at back panel, , Type-C, Reversible)
  • Special Features
    OC Design - ASUS PRO Clock Technology
    - Full BCLK range for extreme overclocking performance
    5-Way Optimization by Dual Intelligent Processors 5
    - 5-Way Optimization tuning key perfectly consolidates TPU, EPU, DIGI+ Power Control, Fan Xpert 3, and Turbo App
    ASUS 5X Protection II :
    - ASUS DIGI+ VRM - 16 Phase digital power design
    ASUS TPU :
    - Auto Tuning
    - GPU Boost
    - TPU switch
    ASUS EPU :
    - EPU
    - EPU switch
    ASUS Digital Power Design :
    - Industry leading Digital 16 + 4 + 2 Phase Power Design
    ASUS Wi-Fi GO!
    - Wi-Fi GO! Function: Cloud GO!, Remote Desktop, Remote Keyboard & Mouse, File Transfer
    - Wi-Fi GO! & NFC Remote app for portable smartphone/tablet, supporting iOS 7 & Android 4.0 systems
    ASUS Exclusive Features :
    - GPU Boost
    - USB BIOS Flashback
    - MemOK!
    - AI Suite 3
    - Ai Charger
    - Ai Charger+
    - M.2 & SATA Express
    - Anti-Surge
    - Front Panel USB 3.0 Support
    - USB 3.1 Boost
    - Disk Unlocker
    - Turbo LAN
    - Crystal Sound 3
    - EZ XMP ASUS Exclusive Features
    - Mobo Connect
    - PC Cleaner
    Remote Entertainment
    - Media Streamer
    - HyStream
    ASUS Quiet Thermal Solution :
    - Stylish Design Heat-pipe solution
    - ASUS Fan Xpert 3
    ASUS EZ DIY :
    - DirectKey
    - ASUS CrashFree BIOS 3
    - ASUS EZ Flash 3
    - ASUS USB BIOS Flashback
    - Multi-language BIOS
    - Push Notice
    ASUS Q-Design :
    - ASUS Q-Shield
    - ASUS Q-Code
    - ASUS Q-LED ()
    - ASUS Q-Slot
    - ASUS Q-DIMM
    - ASUS Q-Connector
    Special Memory O.C. Design
    Overclocking Protection :
    - ASUS C.P.R.(CPU Parameter Recall)
    Turbo App
    Fan Xpert 3
  • Operating System Support
    Windows® 10 , 64bit
    Windows® 8.1 , 64bit
    Windows® 7
  • Back I/O Ports
    1 x DisplayPort
    1 x HDMI
    2 x LAN (RJ45) port(s)
    5 x USB 3.1 (teal blue)Type-A
    1 x USB 3.1 Type-C
    1 x USB 3.0 (blue)
    1 x USB 2.0 (one port can be switched to USB BIOS Flashback)
    1 x Optical S/PDIF out
    1 x ASUS Wi-Fi GO! module (Wi-Fi 802.11 a/b/g/n/ac and Bluetooth v4.0/3.0+HS)
    1 x 8-channel Audio I/O
  • Internal I/O Ports
    1 x AAFP connector
    2 x USB 3.0 connector(s) support(s) additional 4 USB 3.0 port(s)
    1 x SATA Express connector: ,
    1 x M.2 Socket 3 with M Key design, type 2242/2260/2280/22110 storage devices support (Supports both SATA & PCIE SSD)
    1 x TPM header
    6 x SATA 6Gb/s connector(s)
    1 x CPU Fan connector(s) (4 -pin)
    1 x CPU OPT Fan connector(s) (4 -pin)
    4 x Chassis Fan connector(s) (4 -pin)
    1 x S/PDIF out header(s)
    1 x Thunderbolt header(s)
    1 x EZ XMP switch
    1 x System panel(s) (Q-Connector)
    1 x 5-pin EXT_FAN(Extension Fan) connector
    1 x DRCT header(s)
    1 x MemOK! button(s)
    1 x Thermal sensor connector(s)
    1 x TPU switch(es)
    1 x EPU switch(es)
    1 x Power-on button(s)
    1 x Reset button(s)
    1 x Clear CMOS button(s)
    1 x USB BIOS Flashback button(s)
    1 x Water Pump header (4-pin)
    1 x 14-1 pin TPM connector
  • Accessories
    User's manual
    ASUS Q-Shield
    6 x SATA 6Gb/s cable(s)
    1 x Feature manual
    2 x M.2 Screw Package
    1 x CPU installation tool
    1 x Supporting DVD
    1 x ASUS 3T3R dual band Wi-Fi moving antennas (Wi-Fi 802.11a/b/g/n/ac compliant)
    1 x HYPERM.2 X4 with M Key design, type 2230/2242/2260/2280/22110 storage devices support (Support PCIE SSD only)
    1 x SLI bridge(s)
    1 x Q-connector(s) (1 in 1)
    1 x ASUS Hyper Kit
  • BIOS
    128 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI3.0, WfM2.0, SM BIOS 3.0, ACPI 5.0, Multi-language BIOS, ASUS EZ Flash 3, CrashFree BIOS 3, F11 EZ Tuning Wizard, F6 Qfan Control, F3 My Favorites, Quick Note, Last Modified log, F12 PrintScreen and ASUS DRAM SPD (Serial Presence Detect) memory information
  • Manageability
  • Form Factor
    ATX Form Factor
    12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
  • Note
    *1: The PCIe x16_3 slot shares bandwidth with SATA6G_56. The PCIe x16_3 is default set at x2 mode.
    Supports Intel® RST for PCIE RAID storage.
    *2: The M.2 socket shares SATA ports with SATA Express. Adjust BIOS settings to use an M.2 SATA device.
    *3: Supports PCIE RAID configurations via onboard M.2 and PCIEX16_3 slot storages.
    *4: These functions will work depending on the CPU installed.
    *5: These SATA ports are for data hard drivers only. ATAPI devices are not supported.
Z170-DELUXE-ASUS-1101.BIN.zip
