MSI X99A GODLIKE GAMING - MS-7883
X99A GODLIKE GAMING
MS-7883.110
  • Supports New Intel® Core™ i7 processors Extreme Edition in LGA 2011-3 socket
  • Supports Quad Channel DDR4-3400+(OC) Memory
  • Mystic Light: Style your favorite color from now on
  • 2X Faster USB 3.1: Delivering speeds up to 10Gb/s, USB 3.1 offers performance twice as fast as a regular USB 3.0 connection.
  • DoubleShot-X3 PRO: Use Killer DoubleShot-X3 Pro to combine Killer WIFI with two Killer LANs for the best online gaming experience
  • Turbo U.2 SSD Solution: Take advantage from the whole new storage solution up to 2.4GB/s read speed
  • Turbo M.2 : Delivering next generation M.2 Gen3 x4 performance with transfer speeds up to 32 Gb/s
  • SATA Express + USB 3.1 + SATA 6Gb/s
  • Multi-GPU: 4-Way NVIDIA SLI & AMD CrossFire Support
  • OC Engine: Reach higher overclocking results with more flexible BCLK adjustments at 100/125/167MHz.
  • Audio Boost 3 RPO: Hear the sound from the heaven with 6.3mm audio jack and ESS audio DAC
  • USB Audio Power: Serve Stable 5V Power & Better Signal Transmission over USB
  • XSplit Gamecaster: Show off you skills to the world with a 1 year premium license for this popular streaming software
  • Guard-Pro: Improved Protection and Power Efficiency
  • OC Genie 4: Overclock in 1 Second
  • Gaming App: Boost your framerate
  • Click BIOS 4: Easily Fine-tune Your System
  • Nahimic Audio Enhacer: Enjoy sound that pushes the limits of reality.
  • Gaming Device Port: Optimized with Triple Gold-plating for High Polling Rate Gaming Devices
MS-7883 REV1.0.pdf
MSI MS-7883 r1.1.pdf
MSI MS-7883 Rev 1.1 BoardView.cad
MSI MS-7883 Rev 1.0.cad
MS-7883.110.zip
MS-7883 REV1.0.pdf
MSI MS-7883 Rev 1.0.cad.zip
