Bios
VM580D
X550DP x750dp rev2
k550dp
VM580D
X550DP x750dp rev2
k550dp
AMD no Me Region Please downloads one BIOS new above and Programmingasus x550d code board x750dp rev 2.0
need clear me
find and downloads above.download from ?
Here is AMD not use Me Region.x750dp rev 2.0 clear me please
send file BIOS I check and helpHello. Where can I find WinKEY and SN in this flash file to swap from original?
What do you use DMI for? it is available on the caseHere you go. Please swap DMI files from this backup.
Not all laptops have a win license, how do you know this model has a win key in the BIOS?Probabbly we cant understand each other. As I know datas like serial number or windows key for windows 8/8.1/10 are written to SPI BIOS IC usually. And if I'll replace original damaged firmware by firmware from this 1st post without changing data, Windows installed on hard drive will be not activated probabbly.
Thats why I want to swap this DATA from backup to file from 1st post.
But I cant find hex positions to change because they are encrypted I think.
This is an old model that cannot have win 8 licensesI suspect that because under cover I have label with Windows 8 logo (without license) and I think Windows 8 was preinstalled on this machine, and if I cant see label with license, windows key should be in SPI BIOS IC or EC IC.
Please not care versiondo you have version 211? x750dp rev2.0
i can`t update from windows because i don`t have battery
thanks
