W670SRQ_ESM.pdf
after try bios same problem, you need check Chipset and LCD and cable...Hi , i have
W670SRQ model but the mainboard model number is different . the laptop power on and display only on HDMI could that be bios? i have tried new flex and screen still the same
which bios should i try for that specific model
on the sticker say w670
I have tried the bios that you have here is that correct one? How to check chipset? You mean replace gpu?after try bios same problem, you need check Chipset and LCD and cable...
heat up, Reballing, change ... etcI have tried the bios that you have here is that correct one? How to check chipset? You mean replace gpu?
Please clear me.
