Toshiba Tecra A11 S500 FHFLSY1
Kindly help with response code
Toshiba Dynabook B552/H
Serial No = 3D037640H
Challenge Code = MUVX5-E5UXD-519Y1-5KBA7-YQ9KQ
Response code = ??
Thanks in advance
MMs_ms is online now
Report Post
Edit/Delete Message
board FHFLSY1
MEC1618 was shorted
replaced with MEC1619L, tried to program it ,but get Blank Check false
can't flash it
I not see info Programming MEC this
MEC1618
there is pinout info on page 10 in PDF
Software version 1.1.2.3 date 02.03.2023
Running Microsoft Windows 10 Pro 64 bit
Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
.NET Framework Version: 4.8 or later
Device connected in work mode
Firmware version 1.0.7.7 date 2.3.2023
MEC mode selected
MEC IDCODE: B1240020
Device ID: 0
Device Revision: 0
Device Status: 0
Flash Status: 0000000000
Boot Block in not protected mode
Flash Configuration: 0000000000
Start reading: 05/03/2023 7:37:26
End reading: 05/03/2023 7:37:28
CRC calculated 1D0F
CRC stored 0000
Read OK
Start erase in: 05/03/2023 7:37:31
End erase in: 05/03/2023 7:37:31
Erase OK
Start blank check: 05/03/2023 7:37:38
error
Blank Check false
00002339A.pdf
