DA0BLFMB6E0.bin.zip
DA0BLFMB6E0.pdf.zip
you need Programming one bios new above.clear me, password on the bios
you have other bios,the above bioses are not working, you can clear me the above password bios,thank you
check again bios you send me work or not.this bios not powering on bro
yes need change new chip KBC.it is workin fine,have powerin on and dislplay, the problem is password on that bios,
https://vinafix.com/threads/toshiba-l755d-da0blymb6e0-bios-bly.30712/hi i need toshiba c55-c5135 (DA0BLYMB6E0 REV:E) 8mb bios file please
Ohk....I will try .....cannot determine try a new BIOS if same result then you need to check the hardware
I tried it with new bios and it works ok....cannot determine try a new BIOS if same result then you need to check the hardware
core 2 no have builssno data build plz
bios daoblfmb6e0 rev. ccore 2 no have builss
