that's right, clearme and using the wrong BIOS with the original BIOS of the machine will leave this errorhard disk m.2 not detected in bios screen and also second disk sata. Disks are OK.
What is the solution? Can You make clear me from my original bios? Actually laptop doesn't work fine. I don't try any different bios file. thankthat's right, clearme and using the wrong BIOS with the original BIOS of the machine will leave this error
clearme can't work SSD problem you need to program other BIOS when SSD is ok i will help clearme fix late displayWhat is the solution? Can You make clear me from my original bios? Actually laptop doesn't work fine. I don't try any different bios file. thank
REBUILD PLEASE
please clear bios
thanks
what about before clearme?not work, laptop dont power on with this bios
clear me
because freezes has nothing to do with me regionAfter clear me no signal
Before clear me freezes on the Lenovo logo
Rebuildingbecause freezes has nothing to do with me region
need try one BIOS new and only clearme when see delay display
work normawhat about before clearme?
power on and work ok before bios programing, but cant enter bios to change boot order and format itwhat about before clearme?
BIOS not right model LVAC ??Rebuilding
because me region doesn't error if try to clearme it will be worse than i said many times just clearme when delya displaywork norma
builds73212.ziphi sir this BIOS lag on a lenovo logo
