Ask T480S - NM-B471-REV1.0-2017-10-30- Don't turn on
Question & Answer Forums
matcoco
Hello,
I have a question. I currently have a T480S, and I extracted the original BIOS. Then, I tried to use a T480S BIOS I found on the forum. I turned on my computer, and initially, the power LED blinked 3 times, then nothing. So, I tried to restore the original BIOS. When I connect the power cable, the charging LED lights up red and then goes off, and the power LED lights up white and then goes out. In the end, the computer doesn't turn on anymore.
Do you have any idea how to get it to turn on?
T480S.mp4
Hello,
send old bios I check anh help
I'm afraid that the original BIOS might be corrupted. Have you encountered this kind of issue before?
If the original BIOS is corrupted, then install another bios and it should run normally. In my opinion, the hardware is the problem, not the bios
builds7.zip
How can you be certain that the BIOS is corrupted? How did you find out?
