T480 (Type 20L5, 20L6) BIOS (ThinkPad) ET480 NM-B501
BIOS n24uj06w
ME 11.8.50.3460
Intel Management Engine 11.8 Firmware for Windows 10 (64-bit) - ThinkPad T480 (Machine types: 20L5, 20L6), T480s (Machine types: 20L7, 20L8), X1 Carbon (Machine types: 20KH, 20KG, 20KH, 20KG)
ET480 NM-B501
LENOVO_THINKPAD_T480_LCFC_NM-B501 photo
Thinkpad T480 - NM-B501 BoardView.tvw
16MB.bin.zip
NM-B501 1MB.BIN.zip
T480 NM-B501 WD-2 Logic.pdf
197kb.zip
hi u did this builds7321.zip for me and it works but not fully there is still issue
but i also tested the one u got here at 1st page and that is working allows me to boot as should be from usb and so on but there i don't see the nvme
can you please check again the builds7321.zip and i hope can be fixed to work properly
thank you Larry
thank you Larry
i m not able to c the nvme still rest looks working but i m reseeding the original file again - this was after update the disrupted it was just making alien sound at start no image or back-light just sound
please check again as this is what i need to fix as the one from the page 1 is not same in options
thank you LArry
thank you LArry
I gave you two builds that's all that can be done with the original BIOS you provided
It doesn't make any sense even if you send it back
sure i understand but the second build is based on the same file or different please ?
as the first fixed file i can c the SSD in the main page but on the second build it is not there ....
just asking
thank you
just asking
thank you
it shows that the original BIOS has completely failed to fix because the 2nd stop is built from your original bios
