Surface Pro 5 1796
hello
i have a surface pro5 1796 with on/off problem
logo on for 2 seconds and then off
this is my original bios dump
please help build this
thank you
To fix the touch you need the original BIOS of this machine and you can also use it to test the other PC.BIOS Original (2) Surface 4 Pro not work touchscreen
This is what I read from this tablet. Just signed incorrectlyTo fix the touch you need the original BIOS of this machine and you can also use it to test the other PC.
If the touch doesn't work, it's probably not the original BIOSThis is what I read from this tablet. Just signed incorrectly
That's all there is. Is it possible to restore it?If the touch doesn't work, it's probably not the original BIOS
BIOS Original (3) Surface 4 Pro with on/off problem logo on for 2 seconds and then off
send photo s/n number above case I checkthe tablet starts, but in the device manager Surface Integrated sensor Hub, Surface ME and Surface Touch with error code 10. Touch not work
yes, builds don't keep s/n and even keeping it won't solve the problemIn your BIOS another serial number. It`s right?
BIOS this error what ?Intel Management Engine 0.0.0.0
YesBIOS this error what ?
BIOS Original (3) Surface 4 Pro.bin
I ask it error what? befoe that ??
Programming again file thisBIOS this error what ?
