Kinh nghiệm SSS6666 USB mass production test utility V1.51
Discussion in 'Motherboard' started by ThienBui, Aug 6, 2014.
  1. ThienBui
    Staff Member
    Dec 13, 2013
    37,251
    2,938
    If you have corrupted SSS6666 USB flash drive .Fix it now by using SSS6666 USB mass production test utility V1.51 .Download SSS 6666 V1.51 C100Test utility and repair your flash disk now.
    Hello my friends , today i brought to you a solution "Firmware " for repairing corrupted SSS6666 Chip controller .If you have unrecognized or damaged SSS6666 USB stick don't give up , Just follow our lash drive repair guide .
    SSS6666 USB mass production test utility V1.51 is designed to repair corrupted SSS6666 chip vendor that have format errors such as "Please insert disk error message , Windows unable to format disk,Disk is write protected ,....,etc " .
    SSS6666 USB mass production test utility V1.51 only support format SSS6666 USB flash drive so please you must be sure that your flash drive chip vendor is SSS6666 .You can use Chip genius report software or USBDeview V2.30 utility to determine flash drive information easily .
    To learn how to repair SSS6666 USB flash drive , please follow our flash drive recovery tips :
    • Download SSS6666 USB mass production test utility V1.51 from the download links in the end of this article .
    • Insert your SSS6666 USB flash disk to your PC.
    • Open SSS6666 USB mass production test utility and if your flash drive is supported so you will see the flash drive information appears on program interface .
    • To begin format your flash drive , Please Click on Start .
    • Wait until finish formatting ,Don't remove your flash disk while updating firmware .
      If this software doesn't work with your flash drive ,go to the second solution "remove the case of the flash drive and write in a comment the details that exist on the chip controller of flash drive board and i will try to find the best firmware for you .
      You can try this solution also , please read the following articles :
      Server 1 - Server 2 - Server 3
    #1 ThienBui, Aug 6, 2014
    • 0919.47.6686
