Special ! ITE ENE IO Programmer , ITE8586,KB9012,Nuvoton,EDID + Keyboard Module
sas2017
IR16 , vertyanov, svod io programmer , ENE KB9010 / KB9012 / KB9022 / IT8586E, IT8585E, MEC1609 programmer , io programmer , ene programmer , ite programmer
KB9012QF + EDID USB programmer + Notebook keyboard tester, kb9012 programmer
IT8586 programmer
We do not have any activations.
IT8585E - tested on X550LA
IT8586E - tested on NM-A311
IT8587E - tested on ZQK
IT8985E - tested on X551MA
Contact : [email protected]
***Special version***
***3 keyboard socket***
***High amperage supply***
***Type B strong USB socket***
***Fast and easy programming
No Activation All Free !
NUVOTON NPCE288 NPCE388 series
NPCE288NA0DX TQFP128 (no external adapter needed!)
Package Included
1 x IO programmer
1 x keyboard converter pcb
1 x 1.8v bios adapter
1 x 32 pin 1mm cable
1 x 30 Pin 1mm cable
1 x 26 Pin 1mm cable
1 x 24 Pin 1mm cable
1 x 30 Pin 0.8 mm cable
1 x 30 Pin 0.5 mm cable
1 x 26 Pin 0.8 mm cable
1 x 25 Pin 1mm cable
1 x 28 Pin 1mm cable
1 x Dupont cable
1 x 40 pin ve 30 pin lcd edid programmer cable
1 x FC-8P 8 Pin IDC programmer cable
Buy Link : http://www.ebay.com/itm/Vertyanov-I...611949?hash=item28388f5f2d:g:adsAAOSwTLxZhFMK
Campaign : http://www.ebay.com/itm/KB9012QF-ED...920087?hash=item283bbcca17:g:pFAAAOSwk~xZhFJk
HOW UPDATE NEW DATA CONNECTION , PLEASE SHARE.
ENE IO Sample : Mainboard LA-8941P
Schematic Search keyboard pin KSO3 , KSI4 , KSI7 , KSI6 , KSI5
Keyboard pin number contact address write.
Result : LA-8941P KSO3=8 KSI4=14 KSI7=20 KSI6=17 KSI5=16
this information MB connection ENE txt file add and finish ;)
ITE same !
PD0= PD1 , PD2 , PD3, PD4, PD5, PD6, PD7, BUSY, STB, AFD, INIT, SLIN, KSI4, KSI5
Guys... i have contacted Vertyanov himself: this is a ripoff which will not be supported by the further software updates. I asked him if he could contact vinafix admin to fix this post and give right place to buy this kit.
The original device is also cheaper.
if you don't care - you're just stupid since every $$ you paid for the ripoff was stolen from the original developer. This means that newer product for newer IO chips will be harder to develop, so you're literally hurting yourself. Yup, there's no problem in hijacking Apple products, e.g MacBook 2015 data rescue kit, but this is a niche device which could only loan itself if users and buyers will respect author's copyright. So far, this eBay seller literally stole 10k $$ from the development which needs to be supported since newer IO chips come to the market.
any body know, how to read npce288 use this tool?
it seem, it not work 100%. only in la-b091p working, another board that use npce288/388 not working.
please help, if anybody ever success read this nuvoton with this tool. thanks.
some of 288 is bad
it is not programmers problem
you may ask author directly (Vertyanov)
please use new software
Maxim
some of 288 is bad
Maxim
just now i mean for sas io programmer, not vertyanov real version. btw, thanks in advance.
so the newest version of vertyanov, i can buy from where?
LA-C285P EC 388N FFC_PINS = 30 JENK = 23 TCK = 11 TMS = 10 TDI = 9 TDO = 20
LA-C771P EC 388N FFC_PINS = 30 JENK = 24 TCK = 12 TMS = 11 TDI = 10 TDO = 21
Trabaja 100% S A S
[QUOTE = "ThienBui, postagem: 102308, membro: 6"] desculpe, eu não entendi o que você quis dizer. [/ QUOTE]
I was going to buy the SVOD but I was advised that he had a license to record ENE and Nouvoton chips, as if it were a serial. I do not know if it's exactly a license. But in the ad it said that it comes with 2 codes.
HI.
I want to program it8586e for motherboard BE460 NM-A551 for this i need data sheet of pin .... i dont have io programmer i will program this with rt809f trough connect wire/jumper on keyboard connecter plz help
