sas2017
IR16 , vertyanov, svod io programmer , ENE KB9010 / KB9012 / KB9022 / IT8586E, IT8585E, MEC1609 programmer , io programmer , ene programmer , ite programmer
KB9012QF + EDID USB programmer + Notebook keyboard tester, kb9012 programmer
IT8586 programmer
We do not have any activations.
IT8585E - tested on X550LA
IT8586E - tested on NM-A311
IT8587E - tested on ZQK
IT8985E - tested on X551MA
Contact : [email protected]
***Special version***
***3 keyboard socket***
***High amperage supply***
***Type B strong USB socket***
***Fast and easy programming
No Activation All Free !
NUVOTON NPCE288 NPCE388 series
NPCE288NA0DX TQFP128 (no external adapter needed!)
Package Included
1 x IO programmer
1 x keyboard converter pcb
1 x 1.8v bios adapter
1 x 32 pin 1mm cable
1 x 30 Pin 1mm cable
1 x 26 Pin 1mm cable
1 x 24 Pin 1mm cable
1 x 30 Pin 0.8 mm cable
1 x 30 Pin 0.5 mm cable
1 x 26 Pin 0.8 mm cable
1 x 25 Pin 1mm cable
1 x 28 Pin 1mm cable
1 x Dupont cable
1 x 40 pin ve 30 pin lcd edid programmer cable
1 x FC-8P 8 Pin IDC programmer cable
Buy Link : http://www.ebay.com/itm/Vertyanov-I...611949?hash=item28388f5f2d:g:adsAAOSwTLxZhFMK
Campaign : http://www.ebay.com/itm/KB9012QF-ED...920087?hash=item283bbcca17:g:pFAAAOSwk~xZhFJk
its not working with new original software ! only with old or fake copyes
I notebook1 forum 4a and 4b software download and tested no problem friend.
Why are you lying ? Maybe you write Ebay Comment.
All software tested no problem.
why ebay 24 positive feedback comment and why 1 comment Neutral ?
You know the answer is maxim. maybe you did.
you pcb2 version only 1 keyboard connector sas 3 keyboard connector and easy device.. no need adapter.
You lie because you are superior to your device.
Please, everyone, take care.:non:
Maxim ,
The device works smoothly with 4b software. What's your problem?
Look at your business, please.
Good night. :nrg:
Is there a way to increase the timeout when reading/writing ENE chips?
Board Info: HP Pavilion 15-ab127ca (da0x22mb6d0)
SIO: KB9028Q
Why you device error kb9028 ?
Sas write all io no problem
hello
how are you
ı have svod programmer lıke that
but ı have a problem when ı programmıng ıte ıo
ıte devıce not detected
ı have actıvatıon for ıte and novtoun
can you help me
thanks
IT8586 programmer
Package Included
1 x IO programmer
1 x Dupont cable
h
hello
how are you
can you help me
thanks
h
svod programmer not support friend.
only sas and vertyanov programmer support.
sas programmer no need activation
You can text the SVOD support team.
