RZ09-0370 v1.1.1.2_PI411 P1106
BIOS AMD
BIOS AMD
RZ09-0370 v1.1.1.2_PI411 P1106.bin.zip
no sir same conditionRZ09-0370 v1.1.1.2_PI411 P1106
BIOS AMD
I think AMD chip have problemno sir same condition
no power clear this issue
Hello my friend,
I got a Blade 14 rz09-0370. Device turns on only when BIOS Battery disconnected and 10 seconds PWR BTN pressed. Goes immediately to BIOS Settings, after leaving Bios black screen or freeze. Then black screen after restart or pressing PWR BTN again, KB Lights are on.
What I recognized: when it freezes then the green light indicator on the right side stops aswell.
Maybe clear or build?
THANKS!
You are right my friend. I am sorry, 8MB is wrong. It was late, i took wrong chip.8mb not main bios
you need care 16MB
and I think you need check chip AMD
AMD no have build sor clearme
try thisYou are right my friend. I am sorry, 8MB is wrong. It was late, i took wrong chip.
Now I got the right one. 16MB
Can you have a look please?
Thank you
same problem as old or different BIOS??I tried, Black screen, no KB light, only right indicator glowing. Its not working.
I posted 16MB Original Bios above...
remove HDD and check agaianPlease can you check... System stuck after post. Only Bios screen is working fine. After leaving Bios system hangs.
next you need to try a new BIOS to compareDid, removed SSD & PCI WiFi Card too.. No change...
