Ask Request BIOS Dump – NEC MultiSync V463
Question & Answer Forums
112PC
Active Member
VIP PRO
Hello,
I am looking for the original BIOS dump for this monitor/TV:
Model: NEC MultiSync V463
Motherboard Model: 715G5737-M01-000-005I
(Q)JQCCBONN062050Q
Board Version: V1.021 / V1.061
Serial Number: 56019036NB
The unit powers on with a green LED but does not display any image or activate the backlight. +5V standby voltage is present, and when I simulate the PSON signal, the +12V and +24V rails are enabled. However, there is no VBLON or PWM output from the mainboard to turn on the LED driver board.
I suspect the firmware may be corrupted. If anyone has a backup of the BIOS for this motherboard, I would appreciate if you could share it.
Thank you very much in advance!
Best regards,
