Repair Kingston 8GB DT 101 G2 SSS6677 chip usb flash drive
Repair Kingston 8GB DT 101 G2 SSS6677 chip usb flash drive.Use 3s usb mass production utility v 2.162 .
Repair Kingston 8GB SSS6677 Chip Vendor
Repair Kingston 8GB DT 101 G2 usb flash drive with two steps .Download 3s USB mass production utility then follow the following tutorial .If your usb flash drive information like the following information ,you can use this program .If you don't know how to get your usb flash drive information , please read the following article and use chip genius
How to repair usb flash drive in three steps
The 3s USB mass production utility can repair the following usb flash drive info
PnP Device ID: VID = 0C76 PID = 0005
Serial Number: 5&&1EEE9724&&0&&6
Revision: 1.00
Device Type: Standard USB device - USB2.0 High-Speed
Chip Vendor: Solid State System
Chip Part-Number: SSS6677
How to repair Kingston 8GB flash drive
Extract the program then open the program called U3S_MP_V2162,then choose your vid and pid from the menu then press on it
Click on your usb flash drive then press start
wait until finish repairing your usb flash drive
