yes, you need Programming file thisCan you remove computrace? It is activated and the option to turn it off is greyed out.
Even with this bios computrace still has the same issue.yes, you need Programming file this
clear mes ok.bin
so you need buy patch disable computraceEven with this bios computrace still has the same issue.
Okay, I sent payment. Here is the biosso you need buy patch disable computrace
20$
Hi, can you clear me pls? Thanks
no display plz fix CAP10 LA-E321P
bình thườngfix lan giúp Huynh
plz clear me this file s org, mine is no display, thanks in advance.
I check BIOS ready clearmehi pls clear this bios so late display
clsss.zipPlease clear the bios, it became a problem when updating
This bios is incorrect
if there is a problem updating then need to buildThis bios is incorrect
