Toshiba PORTEGE Z930 FAU2SY1 A3267A
PORTEGE Z930
Toshiba portege z930-g1s FAU2SY1 A3267A
Portege R930/Z930 Tecra R940/R950 (PT23x/PT33x/PT43x/PT53x)
All models having part numbers beginning with:
PT234M, PT234P, PT234U, PT235M, PT235P, PT235U, PT330M, PT330P, PT330U, PT331M, PT331P, PT331U, PT334M, PT334P, PT334U, PT439M, PT439P, PT439U, PT43CM, PT43CP, PT43CU, PT43FM, PT43FP, PT43FU, PT43GM, PT43GP, PT43GU, PT43HM, PT43HP, PT43HU, PT43NM, PT43NP, PT43NU, PT530M, PT530P, PT530U, PT531M, PT531P, PT531U, PT534M, PT534P, PT534U, PT535M, PT535P, PT535U, PT538M, PT538P, or PT538U.
PORTEGE Z930_W2Q64CV.zip
original bios version 6.40
I cannot find the same version as EC version 1.20. The fan I have installed is 2.20 and the fan spins at full speed and I cannot install an operating system. How can I find the version that is 6.40?
i don't understand why you need the correct version, with the version only searchable in toshiba support
Because it is the wrong bios. While there is a security boot enabled disabled option under the security menu in the 6.40 version, there is no such area in different BIOS versions, and there is no uefi menu.
My problem continues. The fan rotates at full speed. There is no security boot in the menus and there is no UEFI option. Incompatible bios file. There were UEFI options and security boot options in the original bios file.
make two video problem from Original and builds bios I check
