Toshiba P50-B-108 VG20SQG/20CQG MB REV: 2.1
Hello guys, i disabled the discrete GPU on this motherboard and the laptop takes 4 / 5 min to shutdown !
1. Remove two coils (L8702, L8701)
2. resistor (R3021 to the place of R3020)
Anyone knows this bug ?
If enable GPU, shutdown normally !
Have you found a solution?
yes it takes 4 to 5 minutes to shutdown
anyone knows this?
Same problem as others have reported.
I've disabled the gpu by removing the chokes and moving the resistor. System works perfectly but it takes 4-5 minutes to standby, hybernate or shutdown
I've tried toshiba P55T-a bios (similar board, UMA), doesn't POST. I've tried clean bios from P50-B directly from toshiba website and same problem. All the P50-B P55t family uses the exact same bios because all of them have an amd gpu.
Any ideas?
che
Any ideas?
check hardware
If I re-enable the GPU, the system shutsdown perfectly (but crashes when any gpu activity is present). The costumer doesn't care about the discrete graphics
Just like pcclinic, yasir, luis amaral, I did the discrete to UMA conversion. System works perfectly without the AMD gpu enabled but it doesn't shut down or suspend. We are all looking for a solution. I've spend the last 2 days working on this laptop, trying to mod the bios, removing the vbios module, clean me, reinstall operating system, use CSM mode, etc etc. Nothing works.
Same here :sob:
