M2 need buy patch 35$Hello
can you please repair this bios dont find ssd
Thanx
Hello
Thanx
HP OMEN 17-ck0048tx — No Display — BIOS repair needed
1mb not for ecThis is my EC dump from Winbond 25Q80.
Please provide corrected EC firmware for OMEN 17-ck0048tx.
GPU is RTX 3060 (GN20-E7-A1)
Panel is 17.3 QHD 2560x1440 165Hz (M57128-001)
Need BIOS for 17-ck0048tx with proper RTX 3060 + QHD 165Hz configuration.
Current flashed BIOS gives no display because it is wrong for panel/GPU.
111bbb.zipwhy it's 32mb?
RAM error code appears correctly with no RAM, so BIOS is partially working.
any update? thanksRAM error code appears correctly with no RAM, so BIOS is partially working.
But with RAM installed, fans run and no display, no keyboard, no caps lock.
This indicates wrong BIOS configuration for GPU/panel.
My exact configuration:
GPU: RTX 3060 (GN20-E7-A1)
Panel: QHD 2560x1440 165Hz (M57128-001)
Motherboard: DA0G3LMBCF0 Rev F
Model: 17-ck0048tx
Please provide the correct 16MB BIOS for this configuration with my DMI merged.
What do you want me to do with this BIOS? Other than building, there's nothing else to doany update? thanks
I need this BIOS rebuilt with the correct configuration:What do you want me to do with this BIOS? Other than building, there's nothing else to do
no haveI need this BIOS rebuilt with the correct configuration:
- RTX 3060 (GN20-E7-A1)
- QHD 165Hz panel (M57128-001)
- DA0G3LMBCF0 Rev F
- 17-ck0048tx
And with my DMI injected.
Current BIOS causes fan-only POST with no display/keyboard.
Any 16MB BIOS for OMEN 17-ck series with RTX 3060 — I will adapt it to my board myself.no have
send file 16mb old i check BIDAny 16MB BIOS for OMEN 17-ck series with RTX 3060 — I will adapt it to my board myself.
Here is my original 16MB BIOS dump. Please check BID and provide correct BIOS for RTX 3060 + QHD 165Hz panel. Model 17-ck0048tx, board DA0G3LMBCF0 Rev F. Serial 5CD151M4DB.send file 16mb old i check BID
