NM-A651 L460 Laptop (ThinkPad)
Lenovo ThinkPad L460
Skylake
ECROM IT8586
Machine Type 20FU
Machine Type20FV
L460 20FV BL460 NM-A651 i5-6300U use two BIOS 8MB
Schematics Lenovo ThinkPad L460 NM-A651 Rev 0.1
Is the password or the unlocked bios file delivered?
thanks
The steps you need to follow after payment
You must follow these steps
1. Let find attached the patched BIOS.
2. Remove The Battery CMOS . Also make sure laptop's main battery is out and disconnect the internal front battery if used (many new Lenovo may have an internal battery, the black box) by removing its connector from the motherboard. It is important that the laptop will have NO The main Battery attached and the NO Battery CMOS .
3. Flash BIOS with my attached file please erase it before programming
4.Plug in the AC adapter and press the Power button and start it . You may hear some beeps then you will see the Lenovo splash image, press F1 first second while boot logo to get the SVP password prompt and enter "1234" for SVP and press Enter. Next page will show you Bios-Downloads DXE driver loading and showing "Press any key..". Wait about 50-60 seconds before pressing any Key. Next it will display the warning message and the laptop hardware ID again . Do not disconnect the AC during this process!
-- Write down this new hardware ID . While waiting to receive the response KEY from us, DO NOT TURN OFF the laptop and DO NOT PRESS ANY KEY!
Paid!
TENGO 2 PLACAS IGUALES INTERCAMBIO BIOS Y NO FUNCIONAN, AMBAS FUNCIONAN UNA DE ELLAS TIENE DETALLE DE IMAGEN DISTORSIONADA POR FAVOR CLEAR ME EL ARCHIVO, PROBE LOS BIOS DE AQUI Y NO FUNCIONAN
Hi
Eng ThienBui
there is a problem in this copy it just working for one time
if I turned of the device or did restart for it
the bios needs programming again !
