MSI GS65 STEALTH THIN 8RE MS-16Q2, MS-16Q2 Coffeelake 8th.107.bin.zip5.2 MB · Views: 459
look ther are two IC one is U19 and one is u37 on site support two firmware mark U19 and U37 why is file of firmware bigger?You dont writte me about my repair skill just give me write firmwarePlease go back and study fully before starting to repair. This is just basic knowledge
Just write about U 37 ic ,you upload this bios for U 37,why I can't flash tell me reason..Thanks,no, This shows that you are not technical and did not identify the correct BIOS chip
chip BIOS 126=16MB not 80=1mb, Understand ????
try thisJust write about U 37 ic ,you upload this bios for U 37,why I can't flash tell me reason..Thanks,
Thanks lot for upload I will try ..try this
i flash it,what was issue?Thanks lot for upload I will try ..
hi sir please clear password this bios
hi sir please clear me this bios
so try adding another bios if same problem then need to check hardware, turbo boost doesn't work, when I turn it on, the laptop will reboot, turn it off, everything is ok. and for a long time the laptop turns on to the msi logo
HI SIR THIS BIOS NO DISPLAY PLZ BUILD FOR ME
MS-16Q21 VER 1.1 u19.BIN
bbb.zipbuild dùm em, dòng đẹp, đủ nguồn nhưng lên hình
Hello, can you build and clear this bios
