BIOS MS-14J11 photo
WE DONT WANT UNLOCK BITLOCK..WE WANT UNLOCK BIOS..THERE IS PASSWORD ON BIOS...JUST UNLOCK BIOS PASSWORD...WE TRY ANOTHER BIOS BUT M.2 NOT WORKING THERE...M.2 ONLY WORK WITH ORIGINAL BIOS...PLEASE UNLOCK THIS ORIGINAL BIOS
Which BIOS lock does the video you sent me use? Why is there bitlock?
FORGET ABOUT BITLOCK..I JUST GIVE YOU PROVE ON THAT VIDEO .. WITH THE ORIGINAL BIOS SSD IS WORKING PERFECTLY....WHY YOU DIDNT UNDERSTAND THERE IS A PASSWORD ON BIOS..I JUST WANT TO REMOVE THAT BIOS PASSWORD. ONLY ...THATS IT !
I helped you remove the password but you said the M2 SSD doesn't work
unpas9.zip
I just help you unlock it from the bios you provided, but I don't know about the M2 SSD issue
unpas9.zip
unpas9.zip
but there is no m.2 issue before...m.2 isnt working if i put your given bios...but if we put the original bios again m.2 is working fine...
I don't see that
The video you sent shows bitlock which shows that the BIOS is not original it could be from another PC
If the BIOS is original to the laptop itself, bitlock will not appear
I don't see that
are you mad or something? bit locker isnt a issue...we can format that ssd but for formatting we should go throw the bios..thats why we need unlock bios password ..thats it...but whatever you give bios thats didnt work ssd ...now you give me bios or repair the original one its must be unlocked and ssd should be working ... our bios 100% original
Yes, I'm very excited about the BIOS because you provided it, but now it's my fault.
Does this laptop run on one hard drive or both m2 and sata?
thanks.now everything is working ...please try to understand the exact problem for next time...
